where is the sub woofer limiter menu etc on 3802 please
Discussion in 'Subwoofers' started by mick23, Jun 21, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    denon 3802 page 29 mentions under surround parameters lfe dd or dts a sub woofer peak limit level setting? in system setup menu cant seem to locate this function to make sure it is off thanks all
  2. Jase
    Jase
    Mar 16, 2001
    10,830
    United Kingdom
    +2,723
    Mick
    If the 3802 has one it will be in the Main setup menu. Dont recall ever seeing it on my old 3801, unless my memory is going!!
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    If I remember correctly from your other thread, didn't you say that the test tones didn't work on your sub. It could be that if your amp doesn't recognise the sub that option will not appear on the OSD.
    I wouldn't worry too much about it as I haven't bothered setting it on mine.
