Where is the chest thumping bass located? Poll
In which frequency range does the chest thumping bass reside?
  • 20Hz - 40Hz
    Votes: 14 25.5%
  • 40Hz - 60Hz
    Votes: 26 47.3%
  • 60Hz - 80Hz
    Votes: 18 32.7%
  • 80Hz - 100Hz
    Votes: 8 14.5%
  • 100Hz - 120Hz
    Votes: 0 0.0%
  • Total voters
    55
John24ssj
Simple question to which there are many answers, so where do you think the chest thumping bass is actually located?
noiseboy72
80Hz seems to be that sweet spot for bass, but a large horn loaded speaker will give you that chest thumping bass over a wider range of frequencies.
Many smaller speakers are tuned with a hump around 80Hz as that's where we perceive the "heartbeat" to be most prominent. If you check out the frequency of a bass drum in a military band, they will often be tuned to 80Hz, as it seems to work best to keep everyone in step!
sanjualf
If there was an option of 50-70
I would choose that. Also the article on YouTube is very good as well. Will
Check out his other videos as well
Gasp3621
From someone who reviews and measures subwoofers;
Tactile sensation is mostly felt in the 50 to 125 Hz range (resonant frequency of chest cavity).
Liammonty123
I would say 50hz and above, although with some music with bass lines even higher than 120hz I can still feel the bit in my chest. I think it is a function of placement and spl. The feeling for me only becomes visceral above 100dbc in the midbass region.
D1gita1
Where the option for none of the above?
For that snappy chest punchy you need a fast articulate dynamic system, and one of the most critical attributes to that lies in the time domain. Get that bit wrong and the options in you're poll are all a bit superfluous.
akk0091
I feel most of tactile responses around 30-40 Hz
Below 25 Hz or so I get that "underwater" pressure effect
40-to about 60 Hz I get the thumping effects
In addition to John Wick movies, I find the Dark Knight to be another great movie to test the chest thumping effects. Pay attention to the bass each time Batman fights someone, I bet it's around the 40-50 Hz area
John24ssj
Actually a better question would be at what volume did the chest thumping bass occurs? I realised I only every listen at -10 on the receiver and might never get that chest thumping bass if I'm listening loud enough???
Jase
Prior to watching the video in the link earlier in the thread I'd have said 40-60hz. An extra few db lift at 40hz used to work wonders with my one of my previous Subs (Velodyne DD15).
Jase
Ideally you need to wind up the volume a bit or alternatively up the SW level a few db to compensate for a lower listening level.
You should still get some effect at -10db MV though.
John24ssj
Don't get me wrong the picture frames on the walls shake and the sofa vibrates when bass section come on in the movies but no tactile feedback on the body itself that I was expecting
Jase
What Sub do you have currently?
John24ssj
dual sub setup: BKElec Monolith Plus + XTZ 12.17 Edge
Jase
I would have thought it would be possible with those. Perhaps you're getting more low end than higher up the sub range?
Gasp3621
One thing we have talked with John is he has quite big space with opening. How much that is going to affect it. @John24ssj if you could post a picture that shows the largish room and opening to other space without door.
John24ssj
Floor plan:
Frequency response:
Jase
That's a fair size area, mind you, your current response is pretty good though. Have you tried increasing the SW level a few db over what you have now to see if it helps at your -10db MV listening level?
John24ssj
Well I got a mix of music and movies. I did go 4dB hot and it did give a decent boost but kinda had a negative effect on music where bass became overemphasized thus I didnt bother pushing it further. After Audyssey calibration I do get -8dB as the trim thus I do have plenty of headroom I guess but haven't tried to push it that far.
Jase
Do you use Dynamic EQ at all? If not, just try switching it on and see what it does to the bass. Try the 0db and -5db level offsets at -10db MV.
John24ssj
Yes I am using Dynamic EQ. And I shall give other options a go
Jase
If using Dynamic EQ then tinker with the Offset but don't increase the SW level from where it was set when running Audyssey. If you want to increase the SW level then turn Dynamic EQ off.
It can get a bit overpowering if you increase the SW level with Dynamic EQ on.
D1gita1
Looking at the subs you're using, I'm not entirely surprised at what you report. While the monolith is (was?) famous for being quite musical (usually how people describe a particular punchy subwoofer) it's still a ported sub. Your also running 2 ported subs.
For the most articulate sub bass reproduction you need a very clean subwoofer that times very well. Even the best well designed ported subwoofers ihnerantly move away from what is technically considered the required to meet this criteria. Essentially, the bass needs to be accurate and not be time smeared in any way. Having more that one sub in play makes that more difficult, and a port essentially acts kind of like a sub in its own right. This means your system effectively has 4 sources of sub bass, all with their own individual profiles, and you are trying to get all that to time in perfect harmony, which is no easy task. If there is any smearing in the time domain at all you're going to be moving away from this time domain accuracy goal. Add to this that a lot of ported subwoofers have a tonal character akin to a low Q sealed system, and its quite easy to believe your system is capable of low end tactile rumbles, but might not quite have the real mid bass slam.
Liammonty123
Whilst I agree that time domain smearing is bad, and that you want as articulate system as possible, I don’t think this is the issue.
My main speakers for example, DIYSG HT12s are ported to 50hz, and hit very very hard in the midbass, giving lots of ‘slam’. My old ported 21s, hit very very hard, my sealed car sub, also hits hard.
Many people are getting great results and lots of slam using ported subs and mains. Granted there are group delay issues around the tune of ported subs, further worsened by the use of HPF, but EQing sealed subs also introduces group delay. I don’t want to turn this into the ported v sealed debate that has been done to death, with some insisting sealed are better and ported are better. Yes sealed offers the most accuracy, but I don’t believe that is the issue here. I think the main goal for me anyway, is consistent group delay characteristics across the crossover region.
The many club and festival systems I have heard, all use ported or horn subs to achieve that heart thumping midbass, that we often try to recreate in the home. These systems aren’t as accurate as our home systems, but often sound wonderful.
Similar threads
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
Trending threads
Latest News
Disney Plus announces Star Wars: The Bad Batch spin-off
  • By Andy Bassett
  • Published
LG CX and GX OLED TVs gain AMD FreeSync Premium
  • By Andy Bassett
  • Published
Samsung launches HW-Q950T and HW-Q900T Dolby Atmos soundbars
  • By Andy Bassett
  • Published
AVForums Podcast: 12th July 2020
  • By Phil Hinton
  • Published
QDC Blue Dragon earphones on sale in UK
  • By Andy Bassett
  • Published
