Where is the CD written down?
sniff
I'm about to install Rollup 2. Trying to be prepared for the inevitable disaster and re-install I thought I would find my cd key ...... but can't! :oops:
Before anyone flames me, I DO NOT want their cd key, I would just like to know where it is written, i.e. manual, back of cd etc.
I am certain I haven't thrown it away, just need to think where I would've put it.
I ordered an OEM version from Scan if that makes any difference.
S
Skunkpipe
There should be a small sticker with a hologram stuck to your PC with the OS type and a key on it.
If you didn't stick it to your PC then it's on the cellophane wrapper that the CD/install guide came in
sniff
Thanks,
unfortunately it looks like I have thrown this away! :suicide:
Is there a way of recovering it from the current install?
Would Microsoft issue me a new one if I ring them?
Any suggestions would be greatly received.
Sniff (Idiot)
stuartmc
Cable Monkey
meansizzler, you seem to be the sort of person who is extremlely clever in hindsight. As if you never made a mistake...
sniff, have you found the info you are looking for? If that did not work for you, there are other suggestions known to work.
sniff
Thanks for the suggestions, I used magic jelly bean, and some other one I found off google and they both say the same thing.
Disaster averted - as long as I don't lose the piece of paper I've wrote it on :suicide:
Cable Monkey
A bit of paper taped on the base of the pc is still a good option. :)
Trending threads
