where is referance level on ht amp
Discussion in 'AV Receivers & Amplifiers' started by pdq, Nov 6, 2005.
  1. pdq
    pdq
    i am currently using the kenwood x9060d amp, i have a copy of DVE which i am trying to use to callibrate my audio with. i want to use my spl meter to set the sound level of my speakers. the DVE disc tells you to set the master volume of the amp to referance level, but what is the referance level.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,833
    Somewhere in South Yorkshire
    +6,469
    Moving to amplifiers forum.....
  3. Hairy Herman
    Hairy Herman
    if you have a db scale (-89db or something upwards) then its 0db. If your amp doesnt have that kind of scale (ie it has 0 and upwards) then you will have to ask Kenwood I suppose, or set it to max vol.
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    If your amp has a tone generator, does it vary with changes in volume? If not it is set to output at reference automatically.
  5. pdq
    pdq
    i thought it might be that thank hairy
