I'm recessing wall mount direct to brick wall by chasing out plaster, then putting a 60mm false wall around it, which will have a 60mm recess to frame the plasma...so the pf10 will protrude from that recess by about 60mm.
Questions;
1. Will I be able to have a mains spur (like for the dishwasher etc) chased into the brick right behind the wall mount (there is a square cut in it for this to be poss.) & run the pf10 mains cable behind the back of it to the spur. I would cut the moulded plug off?
2. As the panel will not be flush with the new wall, can I get away with a 50mm frame around it? I'm thinking that even when plasma's are a few cm thinner, this frame size would still be fine. What do you think?
Thanks.
