Where is a good place to buy a TV bracket these days?
ben2579
I bought a great bracket for my 42 inch plasma from a place called 'M form' i think. One of their team used to be quite active on here but has not been online in a few years. They gave great advice and sent quality products.
I have a 32inch PANASONIC VIERA TXL32E6B which i love and bought from richer sounds but now need to wall mount in our loft. Its going onto a stud wall and needs to be able to swivel 45 degrees in both directions. I looked at richer sounds that i usually like but their brackets were very expensive and wonder if this is one of the areas they try and make a good margin now tvs are so cheap.
any thoughts appreciated.
moved from tv forums
articulating-flat-screen-tv-wall-mount-for-32-60-tv-with-80kgs-load-capacity.-tilt-15-to-5-degre-324-p.jpg
We have a tilting and articulating one in our clearance section at £25+VAT
Articulating Flat Screen TV Wall Mount for 32-60 TV with 80kgs load capacity Tilt -15 to 5 degree
Yes tilts , swivels and extends
Used to be over £100 but we don't sell them anymore as concentrate on hd distribution so clearing warehouse
Seb
ben2579
That should be good - what is the best way to fit it to plasterboard? I know there are plasterboard fixings but with the movement of the TV will they move? Or do I find one of the vertical wooden frames in the wall but presumably this won't take all the fixings. Also could I ask how far out it comes when pushed flat against the wall.
Sorry for so many questions.
