Where have my headphones gone?
Discussion in 'LG TVs Forum' started by inviccsuBob, Mar 23, 2018.
  1. inviccsuBob
    inviccsuBob
    Mar 23, 2018
    4
    Leominster
    New house, new LG TV, home cinema kit in storage so use internal speaker. Works fine. Connect Bluetooth heaphones, they are fine too, automatically muting the speaker.
    Sony STR-DA2400ES amp out of storage. Sky box now connected to Sony amp which then connects to LG TV via the same HDMI input as previously. Lovely sound - no headphones. The TV recognises the headphones switching on and asks whether to connect. Click yes and TV says headphones are connected - but no sound. Going through the "Sound Out" section of the TV settings it's clear that it makes no difference whether "Internal TV Speaker" or "Audio Out (Optical/HDMI ARC)" or "LG Sound Sync / Bluetooth" is selected.
    Why is this? What's arriving at the HDMI input from the amp that's different from the Sky box? How do I get headphones working?
    The TV is a 55UJ750V, bought it from John Lewis. The label on the back says so. I can't register it with LG though as their website says there's no such thing.
  2. Dalesman
    Dalesman
    Apr 11, 2016
    143
    Wensleydale North Yorkshire
    +55
    If it’s a new TV, LG May have not got around to updating the online serial numbers on the LG TV listing I had this problem from JL years ago after buying a TV from them albeit was a different make.
    Headphones, is the volume turned up on the headphones switched On and batteries ok. Sorry but that’s all I can offer to check on, you will have doubled checked it yourself I know but...
  3. Dalesman
    Dalesman
    Apr 11, 2016
    143
    +55
  4. inviccsuBob
    inviccsuBob
    Mar 23, 2018
    4
    Leominster
    Thanks for the input. I've given up on that approach and connected to the Sky box via a wifi gizmo instead. That's working fine so I'll leave this as one of life's unanswered questions.
