Where have all the SPL's gone
M
mooky
Ok,
So i was about to order a analog SPL from cornwall electronics only to find that Radio Shack have discontinued the analog one and won't have a replacement until some time early 2004. So Cornwall don't have any, Arghhh !
Anybody know of a replacement or another supplier, should I spend more money and buy the £39 digital one from Cornwall. I confess that £39 was more than I was hoping to pay.
Mark.
Pollywoggle
If you do a search there is info about this, apparently new model coming in everywhere in March or something and the supply of the old ones is exhausted...like me!
M
mooky
A search where? On the internet or on these forums?
RobDickinson
Here, been plenty of threads about it.
hang in there and wait to march or buy a digital one. Or look for a 2nd hand one...u cant have mine btw.
mudan
Established Member
Look on www.radioshack.com and you can see the new analogue one. This should be availabe in the UK soon.
I have the digital one which suits me fine.
M
mooky
Nope. Looked on there. Under
Catalog Home ->Audio->Audio Accessories->Sound Meters
They only have the digital one at the moment. I see no Analogue ones.
rscott4563
I'm also after a SPL meter and wanted to know which one to get, I've read somewhere that some of them don't go down to the low end frequencies and stop around 300Hz, so not very good for calibrating a sub.
Which is the best SPL meter to get??
Ryan :smashin:
amackie
rscott4563:
The digital one from Maplins says in it's spec that it only goes down to 300Hz (accuracy +/- 2dB) , but in practice I've found it does produce readings down to 30-40Hz. The question is how accurate it is at those frequencies though.
If it's for calibrating a sub, then it's probably best getting a meter that is spec'd down to those low frequencies, to avoid any lingering doubts.
Andy.
rscott4563
Originally posted by witters
Surely the point is that, even if it is inaccurate, it will set each channel level to the same degree?
That applies but only if the error is linear throughout its range, however if the error is increased towards the lower frequencies then that rule doesn't apply.
This would seem particularily applicable if the meter actually states it only goes down to 300Hz, but in reality measures down to 30Hz, this may mean that it hasn't been calibrated to measure down this far and so thats why they don't state it as part of the meters range.
amackie
Witters:
We don't know - at least not for a subwoofer.
For the five main channels all getting the same frequencies of band-limited pink noise (I used the Digital Video Essentials disk), then we can accurately measure them and know that they are outputting the same level. For the LFE channel, different frequencies outside the specified range of the meter were used (40-80Hz noise), but as we have no idea of the accuracy of the meter at those frequencies, we have no idea of what the actual sound level is. In practice, I found the meter was reporting a similar level, so it's "probably" the same, but I can't be sure.
antz:
You can get the Digital Video Essentials from Amazon http://www.amazon.co.uk/exec/obidos/ASIN/B00009WW03. Definitely worth getting. For contents, see http://www.videoessentials.com/PALindex.htm. Here's a review http://www.dvdtalk.com/reviews/read.php?ID=7502, which also compares it with Avia.
antz
Established Member
Thanks All!
Not my thread but I've found it very useful and have ordered a SPL from Keene Electronics and Digital Video Essentials from play.com
Regards
Antz
engaged
Established Member
Just rang Keene; they don't have stock of the digital meter by RadioShack - and they aren't expecting the new analog one until April now! Looks like there's nowhere in the UK that has current stock of the analog RadioShack meter...
Z
Zoidy
buy a real time analyser.. the ONLY way to measure spl's accuratly (pricey though :/)
jimcarney
Established Member
Mooky,Try Electronics Centre 16 College Square ,Belfast
02890327357 fax 02890239108. Hope this helps Jim
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
