Where does XPMCE store the channel tuning info?
Discussion in 'Microsoft Windows' started by northernmunki, Jul 23, 2005.
  1. northernmunki
    northernmunki
    As the the title really, expecting to find a database somehwhere but cant find it! Why does XPMCE not use the LCN (logical channel number)?
  2. Werner
    Werner
    it is in the registry...
    hklm/software/microsoft/tv system services/tv autotune
    ts(country code) - input type (local antenna, analog cable, atsc stream etc etc)
    e.g. ts33-1 (france =33, local analog cable=1) , then, on the right you have channel numbers and the dword (when converted to decimal) gives you the actual frequency in hz.
    frequency tables and country codes for various countries here
    http://msdn.microsoft.com/library/d...en-us/directshow/htm/tablesandassignments.asp
    the actual "file" which contains this info is kstvtune.ax
    hope this helps.
  3. northernmunki
    northernmunki
    Cheers, what about the services its found following an auto-tune. Where's the info for these?
