where do i put my speakers ?
Discussion in 'Home Cinema Speakers' started by jtfab75, Jul 26, 2004.
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    just got eltax bi-pole rear speakers from ebay seller. these are the only speakers i'll be using.
    my bedroom is a rectangle shape with my tv at the one end and my sofa bed at the other end.
    do i place the speakers on the back wall in the corners or on the longer wall facing towards my sofa ?
    how far up the wall do i put them ?
    want to put them up today cause i'm off work.
    thanks
    james
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I would put them on the side walls about a couple of feet down from the ceiling. It is always better to trial them in position but it isn't very easy with wall mounted rear speakers
