Where do I buy empty dvd cases etc from?
Miyazaki
My father in law got a dvd camcorder, and wants to get some blank dvd cases to put the dvds in. They must have the plastic outer case so he can make dvd covers of the filming he is doing.
He also wants to be able to make covers for the dvd itself, to make it look better than the basic blank media you get and also the glue or whatever you use to make the dvd cover stick to the actual dvd.
I have no idea where to even start looking for this stuff. amazon, play and cdwow didn't really turn up anything.
Hope someone can help.
Thanks.
pRot3us
Another vote for svp here :smashin:
Miyazaki
Thanks lads. Got the gear from a different website in the end :thumbsup:
HMHB
I use the black cases from SVP. With DVDs you create yourself you must take care not to let the sunlight get at them, so black cases are much better then the clear ones.
overkill
I use www.cdr-media.co.uk. Cheaper than SVP for cases, and a lot of the media as well. Compare postage to see which one works out better for you.
Carl80
Hi folks
Could someone please help me to try and find a thin clear dvd case that can hold 5 discs that overlap ?
I have had a good search without any success, I ordered some from ebay but they where to wide as the case is part of a boxset and would not fit.
One case is damaged and i would like to replace it as part of the set
Cheers :)
Singh400
Hi folks
Cheers :)
Try here.
Carl80
These cases have 2 swinging trays and a disc clicked onto the back .
shall i just look for a clear case that allows you to click the trays into it ?
:lease: help
would really appreciate it
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
