TiVoMad
Established Member
Hi All,
I built my HTPC a couple of weeks ago and downloaded the nVidia trial which worked a treat. After some experimentation, I decided that I would use TheaterTek for DVD playback (with ffdshow) so I purchased it and installed. I then realised that I wasn't sure what would happen to the nVidia decoder (I.E. Would it still expire or would TheaterTek have overwritten it with it's own licenced version). To be sure, I de-installed TheaterTek and then de-installed the trial decoder. After that, I verified that the system could not playback MPEG2 (Decoder error on live TV) and sure enough, that was the case. Re-installed TheaterTek expecting that that would fix it but no, still get decoder error and TheaterTek just hangs if I try to playback a DVD. I tried re-installing the trial and guess what, it worked again. Clearly, something didn't de-install from the trial. I didn't want to waste any more time on it so I decided to purchase the nVidia decoder but to my horror then found you can't order outside North America.
So two questions really :-
1) Is there a program/script/something that will completely clean off the nVidia trial stuff and allow TheaterTek to work with it's own version of the decoder ?
OR
2) Is there a way to buy the nVidia decoder in the UK ?
Any help/advice would be most appreciated.
OR
