Where can i send my tosh SD330 to make it region free
Discussion in 'Blu-ray & DVD Players & Recorders' started by Hambone, May 23, 2003.
  1. Hambone
    Hambone
    Jul 9, 2002
    98
    11
    Edinburgh
    +6
    I got it free with my PF2 but i need it region free as half my DVD's are region 1.
    Any one know where i could send it.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Try Multiregion Magic, Techtronics, or search for a supplier of mods on google. there are a few around.
  3. Rookies
    Rookies
    Jan 4, 2003
    5,509
    +489
    Me wondering if there is a hand set hack hmm
    Me off to search as I just recieved one of these today with my PF2 tv :)
    Hambone what do you have your picture setting set at ie
    Colour, Cont, bright, sharp and what active mode? This on your tv
  4. ferris57
    ferris57
    Jan 18, 2003
    869
    the 330 is hacked with a firmware cd like the 220, so no doubt it'll be on the web to download soon.
    in the mean time you can order the cd from www.dvdchips.co.uk for £20. you just stick it in the player and it updates the firmware to make it multiregion.
    if there's a few of you needing it you could maybe order between you.
  5. Hambone
    Hambone
    Jul 9, 2002
    98
    11
    Edinburgh
    +6
    I might try the CD £20 is not bad
    Rookies
    I've not had a proper chance to fart about with settings but i'm off mon/tue so i'll have a chance then.
  6. Hambone
    Hambone
    Jul 9, 2002
    98
    11
    Edinburgh
    +6
    Got the disc from dvdchips and it works a treat.
    Now region free.
    Thanks Ferris57
  7. ferris57
    ferris57
    Jan 18, 2003
    869
    How is the 330 then mate?
  8. Neophyte
    Neophyte
    Where do people generally go for firmware updates? If this player needs software, and it's due out soon, where should I look first?
    Many thanks.
