Where can i see these in action
Discussion in 'Projectors, Screens & Video Processors' started by aylmera, Aug 15, 2004.
  1. aylmera
    aylmera
    hello, i was just wondering where i can view an lcd video projector in action. I live in leicester and have tried richer sounds but with no luck (they dont even sell them)
    Any help would be much appreciated
  2. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    I would have thought Sevenoaks should be able to accommodate you. Have you tried them?
  3. aylmera
    aylmera
    Thanks very much, i never knew there was one of them in leicester. Just one question regarding their pricing, are they about average, or do they tend to be more expensive than most other stores
  4. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    I believe they are similar to most other bricks and mortar stores in terms of pricing but also like most others a bit of haggling should always be tried :D Also depends I guess on how much you spend with them.
  5. aylmera
    aylmera
    Ok, thanks for your help. I will be paying them a visit tomorrow
  6. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    Sevenoaks in Birmingham told me that they don't do LCD projectors as they're not very good, but it may vary at different shops.
  7. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,796
    Oxfordshire
    +159
    Hrmmm. Nice sweeping statement there. If only life (and projectors) were that simple. Mental note to avoid that particular dealer.
  8. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    149
    Are you sure that was Sevenoaks sound and vision? seems a silly statement from a reputable dealer mate, Sevenoaks are one of very few chains that stock LCD projectors.
  9. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Funny that - I've got an LCD projector and think it's fantastic
    I demoed both a AE500 and Z2 ay my local Sevenoaks.
  10. sirp
    sirp
    Jan 20, 2002
    834
    28
    Derby
    +37
    i was told something very similar by them last year in nottingham, "we can get them in, but dont recommend them"
  11. aylmera
    aylmera
    After visiting sevenoaks in leicester, they do stock lcds and will happily demonstrate them to you, however, they do recommend the dlp ones.
  12. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    The guy I spoke to said they do dlps and not lcds. I remember very clearly the comment about lcds because it was my one hope for previewing ae500 near-ish to me and was :( to hear this.
  13. pierrev
    pierrev
    Jul 7, 2004
    theres a Panasonic shop in Leicester that usually has a Panasonic AE500 permanently on show - about 5 minutes walk from Sevenoaks - you can see a Sony at the Sony shop on High Street and Mays of Churchgate sometimes stock projectors though didnt have one on display as of 2 months ago
