Where can I purchase speaker drive units in Bristol ?
Discussion in 'Home Cinema Speakers' started by torimusic, Jun 3, 2005.
  1. torimusic
    torimusic
    I have a pair of Infinity Reference 50 loudspeakers that are over 11 years old and the foam surrounds on the bass drive units have finally disintegrated. I contacted the agents for Infinity (Harmen-Kardon) and they say that they no longer manufacture the drive units for this speaker.
    I need to source an equivalent set of drive units that will work in these speakers. Does anyone know if there's anyone in the Bristol area that specializes in speaker drive units ?
    The Infinity speakers are rated at 150W, 8 ohm.
    The bass drive units are 21cm in diameter and the mounting holes are about 20cm across from each other measuring from the centres of the holes. There are 4 mounting holes in total spaced evenly around the drive unit.
    I will appreciate any help in this area....Thanks, Torimusic
  2. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    It's not in Bristol but they do mail order.
    Try http://www.wilmslow-audio.co.uk/
    I've sourced a few older drive units from them. They may have an equivalent driver. It might be an idea to remove one of the drivers to see if it has any part numbers or model numbers on it.
    Its worth a phone call.
    Good luck.
  3. torimusic
    torimusic
    Thanks Warpaint.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I am 90% sure that HK infinity parts are stocked by select TV in bristol Fishponds area have a google, also worth asking infinity UK (Harman UK)
