Where can I move my subwoofer to?
streetspirit
My new Kefs 2005.3 look and sound great but still need some tweaking, mostly re positioning. I've currently got the sub on the floor next to the tv stand which means it's very close the front left & right as they're on the tv stand for now.
It does sound a little heavy and could do with less vibration. I was thinking of moving the unit onto the bottom shelf of my book shelf. It's situated in the other corner of the room and is out of the way. I've measured the shelf and it's about 14" high, the sub is 8" It will have about 6" space either side of it for the cylinders at the side.
Is moving it here going to prove to restrictive for the sub and will the bass end up sounding worse?
cribeiro
Always leave a sub on the floor and not on some shelf or in a cabinet.
Inside a cabinet is usually a bad idea.
Raising the sub from the floor can be actually good, since you may avoid a vertical mode, but then you'll need a stable, vibration-free platform (on top of a cabinet is a bad idea, since it is hollow and will resonate).
mswarren
I've been thinking of putting a small sub on the bottom shelf of a hifi rack (apollo mezzo @ 363mm). Would you say that this is a bad idea, I would have thought that a heavy hi-fi rack would supply a sturdy enough base for a sub?
thebigjim
Hey m8, the Sub is not 8", so i would re measure. I got the same 1.
