Where can i get this in the uk?
Discussion in 'Desktop & Laptop Computers Forum' started by scrapbook, Dec 18, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,188
    +546
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,261
    Rainham Essex
    +2,404
    Well it took a bit of searching around but I think this is what you are after:
    www.dabs.com
    Direct Access USB 2.0 Multi Connect Hub
    £28.18 inc VAT
    PRODUCT FEATURES:
    Multi purpose connect hub for use in 5.25 inch drive bay;
    Easy front side access for the most common used peripherals;
    Fast USB 2.0 6-in-1 memory card reader supporting CF Card, IBM MicroDrive, SMC, MMC, SD and Sony Memory Stick;
    Extended connections for FireWire, microphone in and line out;
    2 port USB 2.0 hub;
    Four adhesive covers included to provide one uniform PC front color.
    More expensive as it is also a card reader and they are out of stock at the moment :rolleyes:
    You could always find similar product on the makers web site, but it appears to be down at the moment - www.trustcomputers.co.uk
    Mark.
