Where can i get seperate speakers from?
Discussion in 'Home Cinema Speakers' started by rob27, Nov 6, 2004.
  1. rob27
    rob27
    Nov 2, 2004
    162
    +9
    I like the 4 tall speakers in here....
    Sony Surround
    I only want the 4 tall ones as i am getting a 32ZP48 which has a decoder and dvd player with it !
    Is it possible or what is the speaker model no's..
    Rob
  2. Roohster
    Roohster
    Jul 1, 2004
    3,787
    4
    2
    Derbyshire
    +3,791
    Hi Rob,
    probably not the answer you wanted to hear, but...
    If it were me, I'd forget about using the Tosh's internal decoder.
    Even a budget surround system will outperform it!
    Could you get a better deal buying the tv without the dvd player and go for the Sony package?
    Youd be getting a half decent sub and a centre speaker doing it this way...plus the advantage of a tuner and DTS decoding, which the tv won't do.
