where can I get one of these?
Discussion in 'Projectors, Screens & Video Processors' started by The Spaniard, Aug 17, 2001.
  1. The Spaniard
    The Spaniard
    Jan 2, 2001
    1,105
    Walsall
    +80
    I need to get a good quality 15pin VGA type hd connector to connect to a 10 metre long cable with 5 phonos on the end. I have the cable and the phonos...just need the plug!! Any ideas..I have tried keene electronics and Lektropaks...no luck!
    Thanks guys
  2. Mr A
    Mr A
    have you tried maplin at <a href="http://www.maplin.co.uk" target="_blank">www.maplin.co.uk</a> or farnell or RS components.
  3. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    <a href="http://www.videkonline.co.uk/main.asp" target="_blank">http://www.videkonline.co.uk/main.asp</a>
    they do all manner of pc conectors cables ect.<br />it's where i just ordered my pc-projector cable from
