Where can I get one of these?
Discussion in 'General Chat' started by petrolhead, Apr 19, 2005.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,779
    Newcastle
    +115
    [​IMG]
    3.5 and 2.5mm stereo
    Its for a PMR in case you are wondering
  2. Garfield
    Garfield
    Does it have to be on it's own - most of the ones I know are attached to headsets.
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,779
    Newcastle
    +115
    yes because the wireing is different
  4. Garfield
    Garfield
    I'll give a couple of our suppliers a prod and see what shakes loose, only other way is to cut plug off a £30 headset ... not very practical.
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,779
    Newcastle
    +115
    I have thought about that but someone must produce these, even if they have some wires coming out
