Where can I get non-freeview version of PV500(A)?
Discussion in 'Plasma TVs Forum' started by bkny, Jun 6, 2005.
  1. bkny
    bkny
    May 11, 2005
    104
    16
    As in subject, what is the model number of the PV500 without the freeview tuner built in? I can search for prices when I know that! Anyone know where they are sold and how much? Thanks.
  2. manorlodge
    manorlodge
    Jul 23, 2004
    27
    4
    hi, its called the PHD8 and is the panel only version of the 500. it will not be out until sept maybe so no prices yet.
  3. greyhorse
    greyhorse
    Apr 16, 2005
    445
    I think digitalbiz do the no free view models of the PV500, I know they were selling the Euro model on the PE50
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    THE Mainland Euro stock have no FV tuner Analogue only (why would you want this tho?)
  5. bkny
    bkny
    May 11, 2005
    104
    16
    I don;t necessarily need a freeview tuner (have sky) and form other posts people seem to suggest that the euro/non-freeview might be (possibly a lot) cheaper, hence its a cost decision.
    Also i don;t have an aerial into my living room, only into the bedroom, so to get freeview on the plasma woudl involvd major wiring (and drilling holes into walls/ceilings), also the plasma is going on the opposite side of the room to where the aerial lead (and sky dish) is coming from so would mean another wire trailing across the room. but as i said before just trying to figure out if the non-freview is a couple of hundred cheaper ...
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    it will be cheaper, you can buy direct from germany etc (have to potentially send it home for repair) or from a UK store that imports them via non official channels (check warranty conditions closely) i can see the reason for you decision but if you have an AV amp then the PHD8 will suit better, pity its not out for a while tho
  7. bkny
    bkny
    May 11, 2005
    104
    16
    personally i'd prefer a PHD8 aswell (I have an AV amp, although don't really use it on any sort of loud setting as the kids are asleep by 7pm and bedroom is above the tv room), and would probably be willing to wait, but then looking at av-sales.co.uk the PHD7 costs £2300 and comes with nothing (i.e. no wall mount even, forget about all the terminal board/converts/etc etc), hence I assume the PHD8 would be even more expensive, especially realtive to the PV500 (the PV500 can be had for less than £2K with a wall mount! and the PE50 for £1500 with a wall mount (totaldigital.biz).)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    i would not like to guess the price of the PHD8, but the SD PE30 when it came out was a lot more than the PV500
  9. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    The RRP of the TH-37PE30 was £3k on launch, I think the 42" was closer to £4k (maybe £3.5k)? :confused: Looks horrifying when you see what the current PV500 goes for today. I thought my 37" PE30 was a steal at £2.2k this time last year.
    S.
  10. blueshard
    blueshard
    May 28, 2005
    19
    Yeah, but for me the key issue is why the PHD7 is still at £2300? Following the logic (and the PWD7/PV500) the price should have come down to ~£1500-£1600. Is it because Panasonic thinks the markets for commercial and home HD screens are so different that it can price independently? In which case the price of the PHD8 in the autumn could come as a shock... Any views?
  11. dan23
    dan23
    Oct 31, 2004
    96
    11
    +3
    I can't get Freeview where I live, I was wondering if the PV500 tuner allows you to pick up the basic analogue channels?
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    they have analogue PAL-I tuner as well as FV so yes you will get analogue
