Where can I get component connecters for Tosh TV & DVD?
Discussion in 'General TV Discussions Forum' started by Stevie G, May 29, 2002.
  1. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Just ordered a Tosh telly, but Allders didn't have a clue what component connecters are.....doh! Where can I get some to connect my TV & DVD player?
    Thanks....
  2. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    What model have you gone for Emanef?
    Paul
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Any three 75ohm individually screened phono cables for Video Transfer will do the job. IXOS do a dedicated cable for this purpose. Model number is the 171AV and it comes in 3M and 5M versions. I used the 3M version when I used to have a Tosh TV and it was a quality cable for the price (around £30). You can get it from:
    http://www.hificables.co.uk/acatalog/Cable_catalogue_RGB_RCA_cables_36.html
    or
    http://www.directdistribution.uk.com (under the IXOS Cables Category)
    Other manufacturer's do these cables as well if you're looking for more expensive ones. :)
  4. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Thanks. Don't suppose you could recommend a shop as well could you? The telly comes on Saturday, so I'd rather buy them and know I've got them as opposed to relying on mail order (the speakers I just ordered came today when they should have come on Saturday!)
    I went for the Tosh 36" Picture frame. I know there are known issues, but I got it from Allders for £1420 inc delivery and 5 year warranty, and I'll be checking it throughly when I get it!
    My DVD player is a Tosh SD210E......
  5. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Sorry mate - I don't know any shops that have the specific cables I mentioned. Besides, I'm in Northern Ireland. You could try Dixons or any independant Hi-Fi shop though. Dixons usually do a good range of IXOS cables. If you order online, you could still have it by the weekend. Just phone first to check stock. :)
  6. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Thanks. I might try Dixons tomorrow then. Are they more expensive from them, or should they be about the same. I'm trying to think remember what shops are in Romford.....Sony, Dixons, Virgin....not much else any good....!
  7. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Can't be arsed to go looking round shops for the sake of a few quid..... just ordered them from that first link you gave me groundy.....thanks!
  8. jon smith
    jon smith
    Jun 5, 2001
    3,564
    Leeds
    +227
    Just had an email back from my order. They no longer stock them and they say IXOS have stopped doing them.
    I have emailed Joe instead and will buy from him (which I probably should have done in the first place anyway).
  9. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Yeah, I got an e-mail too, but I've bought the one that's £40 instead.
