Where can I get an extension lead for the Sennheiser HD 555 headphones?
Discussion in 'Headphones, Earphones & Portable Music' started by aldavies, Apr 19, 2005.
  1. aldavies
    aldavies
    I have recently bought the Sennheiser HD 555 headphones, and I am really pleased with them. However, I could do with a longer cable on them otherwise there is only one place in the room I can use them. Does anyone know where I can get a suitable extension lead which will maintain the quality of these headphones?
  2. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    Grado extension cable, from any hifi store, usually about £25 for 15 ft IIRC.
    I've had cheaper ones off ebay, but they usually last about 2 months at the most before dying, so its probably a false economy.
  3. aldavies
    aldavies
    Thanks fot the advice. I'll try one.
