Question Where can I get an 'above TV' centre speaker stand like this?
GAmbrose
Something cheap like this which could attach above my TV would solve all my problems
Any idea where to get one in the UK?
GAmbrose
Actually I might abandon that idea as 6kg seems quite a lot of weight to support in that way.
Might have to get rid of my trusty TV stand that I've had for 14 years :(
BlueWizard
The Clamp Center Bracket seems a bit light. I notice the specs don't give a weight limitation.
I think, assuming the TV itself is not wall mounted, that you could find a similar shelf that attaches to the Screw or VESA mounts on the back of the TV. The Screw holes that would normally be used to attach to a wall mount bracket. Though I suspect that these too have a weight limit, but I would suspect the weight limit would be more than a clamp type mount.
Something similar to the attached graphic. There is a chance you might have to have something custom made. Though I suspect brackets like this exist, I don't have a source for any.
Steve/bluewizard
