Where can I get a Sideclick in the UK?
Keiron
Does anyone know where I can get a Sideclick for an Amazon Fire remote in the UK?
It's one of those remotes that clicks onto the side of your existing remote, giving you additional buttons.
Not been able to find one anywhere.
logiciel
Curry’s and various others.
Keiron
Curry's only have the Apple version. Can I ask who the various others are please? I can't find any!
logiciel
Try a Google search.:)
logiciel
Sideclick produces a whole lot of links on Google - for me anyway!
Keiron
Yes but unfortunately, no UK sellers. Nevermind. I've ordered a refurbished one directly from them in the USA. Hopefully customs officers are so busy they'll just wave it though!
logiciel
Direct Nine.
They’re UK.
My Amazon remote has 3 of the extra buttons.
Plus Mute.
Keiron
Thanks. Comes in at over £60! My order from Sideclick including shipping is $29 so even if I get stung, should still be less than that.
Only reason I want it is I want extra buttons for my amp - just on/off and volume. I do have a Harmony, but tbh it's overkill.
logiciel
How do you do that?
Press A or B?
Keiron
Yes - or, teach a power toggle command t the Power button on the sideclick (not that my Rotel seems to have a power toggle - only discrete on & off - it's usually a case that you can't get the discrete codes!)
logiciel
Thanks for that.
You should get the US one before you could have got the UK - and cheaper.
Keiron
My Sideclick arrived from the USA (through customs with no issues).
It's a really nice gadget. Clever design, easy to set up, nice and tactile.
In fact, they sent me two by mistake...
Anyway, highly recommended as both a device and a company to deal with.
