where can i get a samsung hd945
Discussion in 'Blu-ray & DVD Players & Recorders' started by avnutter, Feb 17, 2005.
  1. avnutter
    avnutter
    Feb 7, 2005
    1,569
    west yorkshire
    +184
    can someone advise me as to where i can get a samsung hd945 dvd player from. i want to hook it up to my newly acquired panasonic ae700. :lease:
  2. hillster
    hillster
    Feb 11, 2004
    720
    Reading
    +29
    Had one delivered yesterday from Hughes Direct (hughesdirect.co.uk), had to wait 2 weeks for the stock to arrive but it was worth it to get a uk model. You could try pixmania but it won't come with a uk plug and there have been a few negative comments about them on these boards when you have to return the good if faulty.
    I had no problems with Hughes, I've only hooked the 945 up to my 32" widescreen via RGB scart but the picture is very good. Waiting for a Pio 435XDE to arrive next week then I can see what it's like via HDMI...
    Good luck with Hughes Direct
  3. avnutter
    avnutter
    Feb 7, 2005
    1,569
    west yorkshire
    +184
    thanks for that, i did,nt know about hughesdirect. i,ve just checked their website and they,re showing out of stock. i also spoke to digi uk who confirmed that they will be getting them in march,
  4. hillster
    hillster
    Feb 11, 2004
    720
    Reading
    +29
    Drop Hughes an email, I found them to be really helpful. They were out of stock when I ordered mine but they had six on order, four of which were already allocated. You might get lucky...
  5. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Digi UK can get them to order from Samsung in 3 days !
  6. zoro
    zoro
    Jan 23, 2003
    326
    +7
    does any one know when it is coming out in US?
  7. kourosh
    kourosh
    Feb 6, 2005
    14,628
    Portsmouth
    +1,045
    you already have them in the states its just the model no are different they are hd-850 and hd-950 look on there home page :eek:
  8. jasonuk
    jasonuk
    Dec 26, 2004
    152
    16
    no. the 950 is not the same as the 945.
    the 850 and 950 of the US is the latest version which wont be released until march and june.
    its worth waiting for them. they are supposed to be superior to the 945.
    do a search for the hd-950 on google and you'll find more info.
  9. jrturbo
    jrturbo
    Hi there
    The unit is available in the USA as the samsung 941 and in hongkong the same unit is known as the 948
    I have no idea why samsung has chosen 3 different model codes for the same playe
    hope this helps
    Regards
    Joe Rubido
  10. TheGaffer
    TheGaffer
