Where can I get a replacement remote for Screenplay 7200 ?
Discussion in 'Projectors, Screens & Video Processors' started by jmbrailsford, Apr 9, 2005.
  1. jmbrailsford
    jmbrailsford
    May 21, 2004
    3,814
    2
    83
    Fife, Scotland
    +231
    As title says, where can I get a replacement remote for an Infocus Screenplay 7200 Projector?
    Been offered the projector at a great price but no remote or manual.
    Manual isn't a problem as I found a PDF on the net, but I would think i will need the remote or can I access all of the features via the PJ itself.
    Will I need the remote once it is setup?
    Any help info would be greatly appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. jmbrailsford
    jmbrailsford
    May 21, 2004
    3,814
    2
    83
    Fife, Scotland
    +231
    thanks for that, will give them a try.
    Meanwhile can anyone answer the 2nd question about operating it via the buttons on the unit itself, as once it's setup I don't suppose I would need to touch the unit much.
    Although I assume it won't autodetect the sources fed into it?
