Where Can I Get A Projector Power Supply?
Discussion in 'Projectors, Screens & Video Processors' started by MikeJeruto, Aug 5, 2006.
  1. MikeJeruto
    MikeJeruto
    The power supply on my Sharp XG-E3500U has begun blowing fuses the instant i load them into the power supply and turn the projector on.
    Recently ive been scouting around for a new one, but i cant seem to find one. If any of you know a direct warehouse or maybe a local store, please maybe post back with a link or something.
    Thanks,
    Zane
  2. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,298
    That's a seven year old unit - you will probably find that even if you can source a replacement power supply it will cost you about ten times what the projector is worth.
    Blowing fuses usually isn't too serious - it's likely that the chopper transistor in the power supply has gone short circuit. Any respectable repair shop should be able to fix it.
    Again though, given the age of the projector, this may not be worthwhile.
    Steve
