where can i get a pc card adapter to slot into a panasonic dmre100
Discussion in 'Blu-ray & DVD Players & Recorders' started by get1a2get1a2, Aug 25, 2004.
  1. get1a2get1a2
    get1a2get1a2
    the 2 slots at the front the pc card slot i need a adapter to slot into the front so i can use my compact flash where can i get one from
    thanks guys
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
  3. get1a2get1a2
    get1a2get1a2
    thanks but in my intructions it says pc card slot
    sd memory card
    compact flash
    memory stick
    microdrive multimedia card
    smatmedia
    xd picture card ata flash pc card
    can i get a pcncia adaptor card
    and put anyof these into the adaptor
    the ones on the site only take compact flash
    thanks
  4. get1a2get1a2
    get1a2get1a2
    have you got this model
    thanks
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    No - but I have had the Panasonic HS2 and have the Panasonic E95 and have used both to pull photos off my Canon camera.
    You need to get an adaptor for EACH type of solid memory you want to use (except SD cards which will slot straight in). If your after an adaptor to read a specific type of memory card do a Google.co.uk search for a suitable adaptor. AFAIK though there is no PCMCIA card that will read them all (someone please correct me if I'm wrong on that!). Do you really need adaptors to read ALL the types of solid media anyway? How many digital cameras/portable devices do you have?
  6. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    A Maplin LY16S (£9.99) works fine with CF cards in my DMRE60 (which has the same card slots as the DMRE100).
