WHere can I get a longer TV-Media Box lead for a Pioneer 435?
Discussion in 'Plasma TVs Forum' started by MartinL36, Dec 1, 2004.
  1. MartinL36
    MartinL36
    DO I have to order it from Pioneer? or can is it a standard one I can get elsewhere? :lease:
  2. alscds
    alscds
    just answered your own question
  3. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Have you seen the prices of the Pioneer ones!!!!
    No idea if you can get a cheaper alternative
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
  5. AndyCS
    AndyCS
    Jul 5, 2004
    79
    9
    Yorkshire
  6. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    What about snipping the existing ones and patching with standard wire? Or should I just get my coat?
  7. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Shut the door on your way out mate :laugh:
    Really not a good idea.
    Cheers, Lee
  8. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Class :laugh:
  9. alscds
    alscds
    make sure you use top end insulation tape for the join or even better chocolate blocks :laugh:
  10. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Wireworld is much better quality cable, but you could buy a cheaper DVI lead and their control cable. 12m control lead is about £100, lindy 10m DVI is £45. Cheaper for shorter runs
    If you don't need the full 10m then Sharps cables for their Aquos tellies work just the same, and there is a 7m kit for about £130 odd iirc.
  11. r5had67
    r5had67
    Nov 7, 2004
    4
    3
    Got my PDP-435XDE installed & wall mounted on 25Nov, only to find the cable between screen & receiver is ridiculously short length. It's only purpose is if you want the receiver right below the screen. As my screen is above a fireplace this was never going to happen. Wife is not happy.
    Priced Pioneer's 10m cable and is a laughable £230. Spoke to the hifi store who supplied screen and they have recommend & tested (and I have subsequently ordered) a 7 metre alternative...the Sharp AN07SC1/2. Although still relatively expensive at £120, it far cheaper than being fleeced by Pioneer.
  12. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The sharp cable works the same cos it is, sharp make the media box. Therefore it's perfectly OK to use, funny it should be 7m, just like Pioneers 433 lead?
  13. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Just to bump this back up, what connector is the data cable? is it a standard connector of any sort?
  14. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,715
    The Borders
    +3,077
    r5had67
    Just a quick note re the Pioneer PDA-H03 10m cable - Pioneer UK don't set retail prices so cant 'fleece' anyone on cables or any other piece of kit.
    Most places supply the 10m cable for just under £200 inc postage.
    Best regards
    Joe
    PS Odd your supplier didn't question the length of the 'supplied' cable if you indicated you were wall mounting the 'screen' - and anything longer than the supplied 3m cable and Pioneer would get accused of supplying a 'ridiculously' long cable for those looking for a 'neat' solution and not wall mounting :)
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Gizlaroc, the data part I have never seen the connector anywhere else, it appears to be Sharp proprietary. They made the 1st gen media boxes, might still be doing the latest ones, I'm not sure. And Joe, the trade on the 10m cable doesn't allow much room for manoevre, does it. And how come the 7m cable from Sharp is 1/2 the price of a 10m from Pioneer. You'd be hard pressed to tell them apart coiled up in your hand. And consider that the DVI part is pretty standard, possibly not up to Lindy quality in fact. Certainly it's not the retailers having a party on this one.
  16. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,715
    The Borders
    +3,077
    Hello all
    MAW - I guess Sharp sell more kit than Pioneer; though I'm pretty sure Pioneer now do the Media Receivers 'in-house' and not sub them out to Sharp.
    Gizlaroc - the MDR20 (or MDR26) DFP connector are available; though I've never seen them sold in quantities of one (or two).
    Best regards
    Joe
  17. danny daniell
    danny daniell
    Jul 25, 2004
    1,649
    2
    +149
    Fellas,
    i just found the Sharp cable for £104 at Robertsons.Will it definitely work with the 505 XDE media box?
    thanks,
    Dan :)
  18. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I promise.
  19. danny daniell
    danny daniell
    Jul 25, 2004
    1,649
    2
    +149
    Thanks Maw,
    Dan :)
  20. danny daniell
    danny daniell
    Jul 25, 2004
    1,649
    2
    +149
    Maw,
    Robertsons cant get this cable for 2 weeks :mad: .Due you stock it?
    Dan :)
  21. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Let me make a call....
    Got one, drop me an email.
  22. danny daniell
    danny daniell
    Jul 25, 2004
    1,649
    2
    +149
    You`ve got mail
    Dan :)
