Where can I get a HTPC audio cable??
Discussion in 'Projectors, Screens & Video Processors' started by Jonny1973, Mar 30, 2002.
  1. Jonny1973
    Jonny1973
    I have a HTPC equiped with a Soundblaster Live player 5.1 soundcard.
    Does anyone know where can I get a cable so I can use digital sound?
    The manual for the card doesn't say what the socket size is. It's slightly bigger than a 3.5 headphone socket. Any ideas???
  2. Guest
    I gather it doesn't have optical out then?
    Are SC's available with coax dig out?
  3. museumsteve
    museumsteve
    Jan 28, 2001
    7,993
    4
    Nth Hampshire
    +1,105
    I have a SB Live 5.1 and use a 3.5mm jack to 2 phono's, standard lead and just plug the red phono into my co-ax in on my amp and I get 5.1, I only found out from here, so as usual thanks chaps..
  4. Jonny1973
    Jonny1973
    Thanks Steve.
    The cable I tried must have had a weird sized connector.
    When I tried a normal phono lead to 3.5mm plug it worked.
    Thanks again.
