Where can i get a cheap vga cable for my samsung to pc?
Discussion in 'Samsung TVs Forum' started by stepp, Mar 19, 2006.
Tags:
  1. stepp
    stepp
    Apr 20, 2003
    1,022
    +34
    i have the samsung le32r41bdx tv and i want to connect my pc to it. Where can i get a cheap but decent cable to connect the two ( roughly 3 metres in length).
    Anyone know the best place to get one?
  2. Puffer
    Puffer
    Mar 20, 2005
    109
    16
    I made the mistake of buying one at pc world but wanted one without having
    to wait for it .
    Anyway try ebuyer the prices look ok there for a belkin high integrity vga cable
  3. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    Here! CPC - the cheapest place for cables on the planet I reckon. Quality should be OK, they do a range if you want to pay a bit more but I reckon that one will do.
  4. lance23
    lance23
  5. stepp
    stepp
    Apr 20, 2003
    1,022
    +34
    Cheers guys......i have found 2 male vga connectors and might make my own cable up.
    Do anyone know if these cables are wired pin to pin ( IE: 1to1 2to2 etc etc )?
    Or anyone know where to find a wiring diagramme for this type of cable?
  6. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    Best of buying one mate, there are plenty about.
  7. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    That's only 2m - he needs 3m.
    I really wouldn't try soldering one m8, it's going to be too much hassle for saving £7!
  8. dacco
    dacco
    Dec 12, 2002
    193
    +5
