Where can I get a cheap 32" monitor?
garethuk
I have just spent hundreds of pounds on building my own Media Center PC and will have to start saving before I can buy the LG 37LP1D which is the TV i really want.
In the interim I would like to buy a cheap 32" monitor to use instead. It does not need to have HDMI, just DVI (for PC) and VGA (for Xbox 360). Ideally I would like to spend no more than £400.
Can anyone advise me where to start looking? Many thanks for your help in advance.
bren.wright
Cheap 32" monitors don't exist! Get saving for the TV.
A 32" monitor will cost around 1k for either a Dell or Apple cinema screen!
Trist
It's over your budget but if you can strech to £600 you could go for one of these.
http://www.avforums.com/forums/showpost.php?p=3337423&postcount=3032
