Where Can I Get a Cheap 16:9 Screen?
Discussion in 'Projectors, Screens & Video Processors' started by GagHalfrunt, Sep 21, 2001.
  1. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    529
    North Cotswolds
    +3
    I have a Sony 1271QM CRT Projector but don't currently have a screen.
    The projector is in my bedroom (no, seriously!) but will only be there for a few months so I don't want to waste money on a quality screen which I'll only have to replace when I buy my house early next year.
    Any ideas and perhaps online sites where I can buy them?
  2. Phil White
    Phil White
    I'm currently using a 'homebrew' screen with my MT3 - and it looks pretty good to me! Nip down to your local haberdashery and buy yourself a cople of metres of 'Offwhite blackout material'. This is a dense heavy and slightly rubberised material. It's normally 54" wide which when you get the calculator out you will discover it's just about spot on for an 8' wide 16/9 image. I've attatched it to a 2" diameter aluminum tube using duct tape. You may need to weight the bottom. Total cost £20. It rolls up too - I'm looking to motorise with a Maplins motor!
    Good luck!
  3. Cliff
    Cliff
    Mar 17, 2001
    6,095
    167
    Kent & Accra
    +3,449
    You can buy screens from photographic shops. These are made for slide or film projection and can easily be masked (with masking tape) using black spray paint. I have masked several screens with each upgrade and it works well. A word of warning, when spraying, cover all white areas of the screen. You only get one chance!
    A good shop for screens and materials is the Widescreen centre in Bakers Street London
    Cliff
  4. pcavelle
    pcavelle
    Jan 23, 2001
    986
    London
    +16
    direkt2u.co.uk/
  5. samwiley
    samwiley
    Mar 15, 2001
    84
    London
    I have sent you a private message about a good cheap screen.
    Sam
