Where can I get 5m PS2/Xbox cables?
Discussion in 'Cables & Switches' started by tomto, Feb 14, 2005.
  1. tomto
    tomto
    Feb 14, 2005
    Huddersfield
    Hello,
    I've just bought a Sony 32" LCD TV that i'm going to be having mounted on the wall opposite my bed in my room. I'm going to be routing cables from this, to a seperate unit/cabinet about 5-10m away from the actual TV.
    This cabinet will have the Xbox, PS2, DVD, and Sky+ box on, and so I need some larger lengths of the cable as the standard ones are only like 2m or so.
    Any ideas? I've tried having a search but it's not coming up with anything useful so i'm hoping someone here has tried something similar.:)
    Thanks in advance.
    Tom
  2. AMc
    AMc
    Nov 20, 2000
    7,615
    Near Norwich
    +4,356
    If you can afford it I would seriously consider a SCART switch (Joytech, B-Tech Quintro+ or a manual one) near your kit and one long SCART lead over several longer runs. Should work out about the same and will be neater.
  3. tomto
    tomto
    Feb 14, 2005
    Huddersfield
    Ahhh, perfect.
    I'll look into that one thanks mate.:)
