Where can I gat CAT 3 cable from?
Discussion in 'Cables & Switches' started by wyerd, Jan 10, 2005.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    Does anyone know? I need 10 meters but I'm having difficulty finding any. It HAS to be CAT 3 as CAT 5 is too thick to go between the carpet grippers and underlay. I'll be using it to extend a phone line.
    Cheers,
    David.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Why not use the correct phone cable ? You will find that single core cable works much better in IDC connectors.
  3. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    I need to use the thinnest possibe cable. BT cable is just too thick.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    CPC? there is some very thin phone cable around............
