Where can I find XS32 firmware updater?
I'm sure I read somewhere that there is an XS32 firmware updater floating around on the net, possiblt on a german site.
Does anyone here know where I can find it?
Better still has anyone tried it? And been successful?
If anyone has any news or information that they could pass on to me, it would be gratefully received.
Many thanks in advance,
Matthew
redsox_mark
Here is the link:
http://www.toshiba.de/consumer/dvdsupport/89/
There is one for hardware version 13, and one for hardware version 14. (My firmware version shows as 1414; the first 2 digits is the hardware version). The update is to 1415.
I haven't tried it...
I asked Toshiba UK, and all they said is that there is no update currently available in the UK.
Mark
Thanks for the link.
I've had a look and all the instructions are in German, funnily enough, so think I'll pass for the time being.
Thanks anyway,
Matthew
J
jdarushall
Matthew Attoe said:
Matthew
Since my old machine was classed as un-repairable I tried it out.
Put in CD and switch off and back on then say yes.
Changes the DVD drive software from 1414 to 1415. Didn't do anything to menus language etc.
It did seem to read discs quicker but the problem with the machine was the drive was faulty.
It may do something to any multi-region upgrade you have and I guess thats why no one will try it. I can't say since this machine wasn't multi-region to start with.
Download the file ver13 or ver14 burn the file as an image using disc at once and finalised.
My machine is version 1310 - will this update it to 1313 or 1415? It is also multiregion, so not sure whether to try it or not.
Decisions, decisions...
J
jdarushall
First time I'd hear anyone with a V1310.
It does say in the instructions that if your version is 13xx to use the version 13 upgrade to make it 1313.
If the mulit-region is via a disc that alters the firmware on the DVD drive ie like computer ones then it may de-mulit-region it as well.
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
