Question Where can I find these speaker connectors? (photo included)
Discussion in 'Hi-Fi Stereo Speakers' started by Shenker44, Aug 25, 2018.
  1. Shenker44
    Shenker44
    Aug 23, 2018
    7
    London
    Anyone know where I can find the right speaker connectors for my Pioneer system? Photo below. I believe I need a 4.2mm connector. I've found a few results on eBay but the prices seem a little steep for a couple of connectors. Thanks!
  2. dannnielll
    dannnielll
    Sep 16, 2017
    2,208
    113
    ireland
    +931
    I think that making an acquaintance with your local dump, recycling centre is in order. . Loudspeakers with these connections are constantly being thrown away.. it a standard fitting on very low cost kitchen or bedroom systems and on some of the lesser quality home cinema boxes. .. that's not being snobbish , I have a Sony with similar fittings by my bedside.
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,143
    Poole
    +11,758
    They are crimp connectors so getting cables with them already fitted is best @dannnielll has the right idea, maybe a charity shop as well.
  4. gibbsy
    gibbsy
    May 17, 2007
    14,475
    3
    Cwm Cynon, De Cymru
    +8,323
    Skip shopping, love it!:thumbsup:
  5. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,143
    Poole
    +11,758
    Got you own dive board?
  6. Timmy C
    Timmy C
    Oct 10, 2003
    5,647
    +573
    I think these are probably the same ones I have (or rather don't have) on a Pioneer 5.1 system I bought on ebay. Seller told me everything aside for speaker cable was included which didn't seem like a problem until a year or so later when I tried to set it up. I searched high and low at the time and only found very overpriced ebay sellers that could help so gave up. Please do post back here if you find a place though!
  7. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,621
    +4,305
    That looks like the Pin Header for a Computer Fan. I'm not sure where you can get them as they are usually used on Computer Mother Boards.
    Steve/bluewizard
  8. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,143
    Poole
    +11,758
    Basically yes but 4.2mm pitch instead if 2.54mm.
