Where can i find a Litepro 580 cable!
Discussion in 'Projectors, Screens & Video Processors' started by woodsy99, Jun 6, 2005.
  1. woodsy99
    woodsy99
    I have inherited a Infocus Litepro 580 LCD projector. I know its fairly old but it would be magic if i could hook it up to my computer. I discovered that it is in great condition with a new bulb apart from the vital Vga cable to hook it upto to the PC!! i have looked everywhere but cannot find the cable i need, only 15 pin male to male connectors. I need a what looks like a 15 to 26 male to male connector... help me before i have to end it all !!! :lease: :suicide:
    i have attached a picture of the connection on the projector.
    the other end should simply plug into a standard pc video card
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    No idea where you might get one, have you tried Infocus themselves?
    As a workaround, is there any other connectors on the back of it? If it has component it may be easier to get a VGA -> Component cable.
    Good luck.
