Where can I buy a power converter?
Discussion in 'Cables & Switches' started by carefactornil, Aug 21, 2005.
  1. carefactornil
    carefactornil
    Feb 19, 2001
    190
    16
    UK
    Don't know if this is the right forum...
    I need to buy a power converter for an american unit (rf extender for my remote control) for use in the UK. Bluedo.com sent me one with my purchase, but I need another.
    The one I've got is a "Seven Star Deluxe 50 Watt travel converter".
    Does anyone know where I can get one in the UK (shop or on-line) - I'm not having much luck at the moment. Don't want to import one as the postage will cost more than the unit!
  2. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    try keene electronics www.keene.co.uk. If the power is supplied by a power brick you can always replace that instead, just choose something with the same voltage and the same or more (mili)amps. This should be details on your current brick. Most come with different heads (don't forget to check and double check polarity. Try Keene or Maplins for a good range
    Rajiv
