Where can I buy a DVI/HDMI hub?
scookar
My tv has one DVI input which at the moment has my dvd player connected to it.
i want to connect my pc up to it too but don't want to be switching cables all the time.
is it possible to buy a HDMI or DVI hub that will allow multiple devices to connect to a single HDMI or DVI input?
did a search on google and all i could find was the Gefen HDMI splitter which does the opposite to what i want.
Cheers.
scookar
gizlaroc
Zektor do a 4 in 1 out as do many others, but they are all going to be that price or higher.
rpm
best option is to buy a new receiver which has HDMI switching.
£800 for the new Yamaha RXV2600 much better money than £270 just for
a switcher!
gizlaroc
What if you are using £10k's worth of processor and amp?
Somtimes a £270 switcher is a better bet. :)
Joe Fernand
AVForums Sponsor
Hello sookar
Its going to cost £200+ to get a multiple Digital signal switcher into your system.
An AV Receiver with multiple HDMI switching would be a good option if your didn't want to include a PC in your list of sources - the HDMI inputs on the AV Receiver may not work with the resolutions your PC is outputting; the AV Receiver is likely to work with Video signals only.
You also have to look at how these devices 'integrate' with your system - the Gefen box's are usually odd shapes and sizes and have cables sprouting on all sides; which is fine as long as you can keep them hidden away.
The Zektor DVS5.1 is a five Input DVI (with HDCP) + Digital Audio switcher with full IR control plus optional RS232 module.
You can programme the DVS5.1 to react to Input selections you make with any remote - your Amp being a favourite as you then have seamless Video and Audio switching.
The DVS5.1 will work with HDMI and DVI sources into your DVI equipped Display and is guaranteed to work with signals up to and including 1080p with no signal degradation.
A DVS5.1 will currently cost you just under £330.00 in the UK - see http://www.zektor.com/dvs51/index.html
Best regards
Joe
steve10574
pointyone
why not go vga from pc to tv or if such a cable is available
dvi to component
Butch499
Hi guys, can I hijack this thread?
This is a qestion for Joe, using his knowledge about interconnects, and it kind of ties in with this one.
Are all HDMI sytems 'guaranteed' to be compatible, as far as you know?
Bumper and I have exactly the same issue, but I cannot be sure that HDMI was working before the region code hack was applied to my HT-P1200. It seems to be device sensitive.
http://www.avforums.com/forums/showthread.php?t=296637
Any thoughts? I seems a switcher might help sort out any small incompatibility in HDMI signals/levels/any other hickies ?
Thanks for any feedback.
Joe Fernand
AVForums Sponsor
Hello Butch499
Odd that for both of you the First Display device you tried via HDMI after you ran the Hack is the only device not displaying an Image!!!
HDMI.org specifies certain signals and accompanying tolerances that should always work over an HDMI connection.
Hardware manufacturers (inc Samsung) can choose to ignore the rules if they want so HDMI can be more problematic than pretty much every other video connectivity standard on the market.
A Video Switcher is unlikely to resolve the problem your having - a Video Processor that allows you to enable/disable EDID and adjust the various timing parameters of the Output video signal may help.
Have you tried your H78 with another HDCP encrypted source device?
Best regards
Joe
Butch499
I have another Samsung source, an HD-850 (also hacked :nono: ), and I tried this early on in the fault finding process & that worked. But I'm going to unhook it and try again on the pj. Double-check!
Thanks again.
Trending threads
