Where are the screensaver files located?
Discussion in 'Computer Software & Operating Systems' started by drunkenmaster, Jan 14, 2008.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    I want to add a screen saver to replace the boring ones that come with XP Pro. But cannot remember where it has to be put for it to be recognized by display properties.
    Any decent sites for free screensavers, without all the notoriety that many come with would be welcome as well
  2. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    C:\WINDOWS\system32
    Although, you can place them anywhere. All you have to do is right click on the SCR file and click Install. It will then (or should) install the screensaver file to the correct location.
  3. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    Cheers for that - it would not install via clicking, thanks anyway
  4. Sofix
    Sofix
    n Windows 3.1: Go to your "Main" group and double click on "Control Panel". Then double click on "Desktop". The screen saver section is the third box down. In Windows 95 or NT: Click on Start, then choose settings, then control panel. Double click on "Display" and select the "Screen Saver" tab.
