Where am I going wrong with Sky Q and Denon?
Dinglebert
Firstly the hardware
Samsung UE55RU7470U
Denon X2600H
Sky Q
Setup
Input: HDMI from Sky Q to Denon
Output: HDMI from Denon to Samsung AV3 HDMI Arc input.
The problem
I have to switch on Denon first. If I don't then I have to reboot the Sky box to get a signal.
When I do switch on Denon first there are times the TV will also start working, but then again there are times it won't.
The Denon is normally only on the Sky signal, however, occasionally its jumped over to my HD player even when its not been used.
Moving it from HD player to Sky will in the main not do anything. It won't pick up the Sky signal meaning I have to reboot Sky box again.
Sometimes it all works but then decides seconds later not to and then its reboot time again.
When its working there are no issues its stable as stable can be.
I have updated my Sky box software to latest.
I have updated Denon software to latest
Samsung I am unsure if its updated or not. When I try to update it tells me my signal is poor at the end of the process. Its not the router is inches away on a fibre to home package. However Samsung then says software has been updated to current date.
While I can cope with all this the OH can't and obviously its all my fault!
Hopefully explaining all these.
Singh
It's probably the Sky box, which has a reputation for being buggy. I have similar issues with a X3500H so keen to hear if anyone has a solution.
As a work around you can connect the Sky box directly to the TV and use ARC for the sound. I've been doing this and it's been working well.
Samsung UE55RU7470U
Denon X2600H
Sky Q
Setup
The problem
HDMI CEC and ARC.. Switch the bloody things off . I assume you are not using ARC much as you say the Denon is usually switched to the Sky input.
It's nothing to do with the Sky box. If you are using sources connected directly to the AVR, plus TV apps using ARC, you will have problems with HDMI CEC. One or the other only you will be fine.
Singh
Thanks, is the problem CEC on the AVR, the TV or both?
Dinglebert
Unclear about what the solutions mean?
If I connect my Sky box direct to TV then its bypassing the receiver which in turn means the sound will be out of the TV and not the speakers. The only other output from the Sky box is the optical cable.
Both, it's how they interact, it's unpredictable. If you keep everything on ARC (or AVR) then you avoid all the handshaking issues when you change inputs.
No, don't do that. Leave it as it is, just switch off the HDMI CEC and ARC on TV and AVR.
gibbsy
There is a known problem with SkyQ and a few different makes of AV amps. Searching the Sky forum you will find plenty of information about it. It leads to black screen syndrome which requires a full re-boot of the SkyQ box. Sky blame the manufacturers and the manufacturers blame Sky. I've had the problem with the 2TB box on my last two Denons, X6200 and X6500.
You have to get into a routine of turning the Denon off if you are using HDMI pass through and let the audio return to the TV speakers. It's then safe to turn Sky off. Also do this before you change sources from the Sky box to say a blu ray player.
Sky did release a firmware upgrade a few months ago that did go some way to addressing the issue although they still do not admit a fault with the box. Make sure your Sky firmware is up to date.
Dinglebert
Sorry I probably shouldn't have technology. I can build a PC from components but setting up a sound system is confusing the heck out of me.
When I go to the settings on the Denon for audio, the first question it asks is do I want to use ARC. If I say no I get three choices, arc, optical or the old stereo red/black setup.
Dinglebert
It is I did it yesterday. I have this problem in the early days of the receiver at which point Sky denied the issue but Denon said it was their fault and were going to be issuing an update to fix.
If you have the Sky Box connected directly to the AVR, then ARC or the alternatives quoted only apply to audio FROM the TV. As your Audio from the Sky Box is not coming from the TV, the setting is irrelevant.
Just switch off anything related to ARC and HDMI CEC on both TV and the AVR (for the third time!).
All I can say is that I have not experienced such an issue with my Sky Q box and Denon X3700H.
Dinglebert
I understand what you are saying but I can't switch off ARC as a choice. My only choices are ARC, optical or old stereo.
No you don't understand what I am saying. If you select optical or stereo, you are by default switching off ARC!
Broadsword
Surely ARC is only enabled if a HDMI cable is plugged into the arc hdmi socket? Do you know which hdmi socket is your arc one? Just use a different one. Go into your tv settings and amp settings and turn off hdmi control or cec.
I have the x2600 so I can check for you when I get home if you wish? You shouldn’t need to be in any menu option relating to optical, ARC or stereo, is that an option in your tv?
Just try a non arc hdmi socket and turn off hdmi cec and then see if it helps. If it doesn’t you can try using an optical cable maybe. If you don’t need atmos it should be fine with sky.
Dinglebert
No its on the TV Audio setup assistant on the Denon menu.
The OP is connected to the ARC HDMI on his TV, but to try and keep it simple I have recommended that he just switches all ARC and HDMI CEC off. He could of course also as you say connect to an non ARC HDMI, but if it's all switched off he will not need to.
Broadsword
He needs to turn arc off on the the tv then not on the amp. He can always try an optical cable for the apps instead of arc, but it’s likely hdmi control that is the issue.
Yes, he needs to turn it off on both -which I explained to him on earlier posts if you review them.. HDMI CEC is the issue, but ARC needs HDMI CEC engaged to work, so just turn the whole lot off and done with it!
Dinglebert
By apps I am presuming you mean Netflix, Disney + etc. In which case I don't have any issues as all my apps are on the Sky Q box. The last one I switched over was Netflix a couple of days ago and managed to save £9 a month in the process by paying Sky for Netflix tha Netflix direct.
Yes that is fine. If you view the apps via the Sky box then that is the easiest way to do it.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
Latest News
Austrian Audio launches Hi-X65 headphones
  • By Andy Bassett
  • Published
Roku expands streaming content with Roku Originals
  • By Andy Bassett
  • Published
What's new on Netflix UK for June 2021
  • By Andy Bassett
  • Published
AVForums Podcast: 12th May 2021
  • By Phil Hinton
  • Published
Bluesound unveils new generation of Node and Powernode audio players
  • By Andy Bassett
  • Published
