Quantcast
When Worlds collide: The dedicated living room cinema (Updated Dec 2018)
KelvinS1965
Updated Dec 2018: Jump to page 20 onwards for completion pictures.
With apologies to George Pal for the title, this is my second attempt at a home cinema hopefully taking some things into account I've learnt over the last 9 years since I built this one:
KelvinS1965's setup.
As the builders are here today finishing off the new French doors (I know, yet more light to deal with :eek:) I thought it was time to introduce my new project. The room is being reversed from the previous layout mostly for it's role as a living room, but it will allow me to build a proper screen wall and some other improvements.
It will be very light for living room use, but I'll be installing 3 metre long black Devore velvet electric side curtains to improve contrast for projector use, plus electric black out blinds in channels to completely block out any light. I also have a plan for some kind of moving ceiling 'covers' with more black Devore, which will come out about 1.5-2 metres depth from the screen, which will run along the new ceiling pelmet that will go right round the room. One thing I've learnt since my last build was how much difference having dark materials around the screen makes to the picture.
Pictures to be added later.
KelvinS1965
Updated Nov 2019:
Current kit list, 5.4.4 layout:
Video:
Sony X800 UHD BluRay player.
Lumagen Radiance Pro for video calibration and Dynamic Tone Mapping (HDR>SDR2020). Used with Chromapure autocalibration and Display Pro 1 sensor.
JVC X7500 projector and fixed Seymour XD 3.0 metre wide 2.40:1 aspect screen.
Panasonic 50E6B LCD TV.
Audio:
Arcam AVR390 receiver. Powering one pair of Atmos channels.
Arcam P7 FMJ power amplifier. 230 watts per channel all channels driven, powering LCR, side surrounds and one pair of Atmos channels.
2 x iNuke 6000DSP power amplifiers for the 4 subwoofers.
MK Sound MP300 on wall speakers for LCR.
MK Sound S150T Tripole on wall speakers for 2 side surrounds.
MK Sound MP150 on wall speakers for 4 Atmos channels.
2 x 15" sealed Fi Q series DIY subwoofers front left and right corners.
2 x twin 8" MK Sound IW28S in wall subwoofers rear left and right corners.
Control & lighting:
Harmony Ultimate remote/Philips Hue lighting/MI|Home remote sockets controlled by Alexa hub.
Neet HDBT Lite extender kit.
Fun:
Marshall SV20H 20 watt valve head & custom 2x12 cabinet with Celestion Heritage Greenback speakers. :)
Supplying dealers:
Jagdeep at Epic Home Cinema. Epic Home Cinema - Home Cinema Retail and Installations
Richard at Seriously Cinema. Bespoke Home Cinema Installations SeriouslyCinema
Ricky at Kalibrate. Kalibrate Limited for Home Cinema products, Calibration, DVD Players, 3D Glasses and more....
Gordon at Convergent AV. Convergent AV - Audio, Visual, Consultancy and Sales, Surrey, UK
Seriously Ltd
AVForums Sponsor
Hi Kelvin,
Finally!!![emoji6]
Are you using your MP150's and what about surrounds?
KelvinS1965
A bit more detail about the project:
The objective is to have an absolute minimum of visible AV gear on show, so only the TV screen and one pair of surround speakers should be noticeable to anyone walking into the room. I moved my AV rack out of room under the stairs last year, so that's one job already done (albeit I'll have to run all new cables from this rack since the subs and speakers will have moved to opposite ends of the room).
It will have a 3 metre wide 2.40:1 aspect drop down acoustically transparent Seymour XD screen with a custom bottom extra wide bottom border so that it reaches the floor and hides the wall behind. There will be a 50cm deep screen wall to hide the subs in and some acoustic treatment, with the LCR hung off this wall, but hidden behind an AT covered fabric panel that will drop down when the screen is lowered so they are only firing through one AT surface at any time.
Speaking of subs; I will be recycling my existing 2 x 15" FiQ subs at the front corners, but also adding 8 x 10" Peerless XLLS speakers: Two twin pairs at the front at the ¼ width ¾ height positions. At the rear two BK IW300 at the ¼ width, ¼ height positions and two more in DIY boxes at ¼ width fixed to the ceiling inside the pelmet. These positions have been modelled with REW room sim and also with some test measurements using my existing 15" subs and a BK XLS200 I use in another room which happens to use the same Peerless 10" driver. This spread of 'mid bass' drivers should finally nail any nulls I've suffered with my existing layout, plus additional acoustic bass traps built into the pelmet will help.
I'll be reusing my MK MP150 for LCR, S150T for side surround use and two pairs of older M&K K5 speakers hidden in the pelmet for Atmos duties. It will be a 5.1.4 set up (or 5.10.4 if you want to count all the subs :) ), with Dirac correction on the 5 'bed layer' speakers and the three groups of subs using the new MiniDSP 'Bass management' plug in for my DDRC-88A.
KelvinS1965
Hi Kelvin,
Finally!!![emoji6]
I edited while you posted (knew I wouldn't be quick enough before someone posted!). The S150T will be the only pair of visible speakers in the room, though being white and the wallpaper is fairly light they should look pretty discrete.
KelvinS1965
Well as you say, French doors (plus a patio door and another window) could be a plague and make the room very light. I just hope the black out blinds work as well as I hope. They will be a dark 'Mulberry' colour so will also help with the reflections back to the screen.
This is the current state post French door fitting:
This is the view facing where the new screen will go (horribly bright in this picture, but I hope to reference back to this in a few months time):
This is the existing AV rack under the stairs. I'll be adding another iNuke 6000DSP to power the extra subs and I'm having a 32 (or 40) amp separate ring main circuit run to supply it rather than be on the standard ring main:
I've since added a Harmony remote that works by RF so I can control the equipment in the rack from the living room or the conservatory.
Davidjake07
Great Space , just a idea but why don't you use simple control running on an IPAD ,i had a few harmony remotes over the years but would not want to go back after using simple control
Here's a link to website :-
iPhone and iPad Universal Remote Control for Home Theaters
works really well with 2 way feedback controls all your devices over IP
KelvinS1965
I have had a play with apps on my iPad/iPhone as I have Marantz AVRs in both rooms. They are both work devices, so the only issue is that I have to careful about what apps I put on them.
TBH the Harmony works so well that I don't really feel the need to look for another solution right now, but never say never, so I may look again once it's all up and running. Thanks for the link.
KelvinS1965
Further info about the subs:
I have to place both my 15" subs at the front of the room as there won't be space at the back as my previous set up. This causes a big null from the pair around the 65Hz region. Instead, I'm going to split the subwoofer channel so that 'ULF' goes to the 2 x 15" subs (ie they will handle 30Hz and below). The 8 x 10" drivers will take over above that, though I may allow them a gentle roll off rather than a sharp filter so that they add something to the output down to 20Hz.
As it isn't something generally recommended I tried some REW measurements before I took the room down. I could only have 1 x 15" front left and 1 x 10" at the various rear positions (mostly the 1/4 width, 1/4 height which is where the BK IW300 will be used).
No LCR speakers were connected during this test, so the measured response rolls off above 100Hz (I think I had an 80Hz crossover setting). It matches very well with the REW room sim, so I'm hopeful that once all 8 x 10" are added that I will have a pretty good response to start with, leaving much less for Dirac to deal with. It should also provide very good seat to seat response, although I will focus on the main MLP it doesn't hurt if the adjacent seats sound good too.
This shows the 15" as the 'ULF' in blue, with the dip around 65Hz and the red being the single XLS200 which has a 45Hz null from this postion. The combined output of them both being the green trace. This took some working out using different filter slopes (both were fed from my iNuke 6000DSP which has a good selection of filters available). This was the best response, but the final set up will have more 10" at the front and at the ceiling at the rear, so I think there will be lots more REW sessions to optimise the result.
Just to show the combined result on it's own for clarity. There is plenty of extra output around 27Hz, but this can be pulled down using the iNuke DSP or Dirac, or even left as a 'preference' for extra low down kick. Note that with extra 10" drivers and the LCR in use the response will not roll off so steeply. If I add a simple 6dB/Octave roll off to the whole sub signal (which can be simulated in REW) the response ends up pretty flat. Not bad considering there is no eq involved at this point:
KelvinS1965
I've been using 'Sweet Home 3D' to plan the layout, so here are some pictures to show the intended layout:
2D from above, showing the false wall which will hide the subs (and a 2 x 12 guitar amp cabinet too :)):
3D view from the MLP, you can just make out the gap on the right side of the false wall. This is where the black Devore curtains will retract to when not in use, same for the left side of course:
This is the view from the front right corner. You can see the two S150T white tripole surround speakers and just beyond the right side of the sofa is the grille from one of the IW300 subwoofers (which will be painted to match the wallpaper, so should be less obvious than in this picture):
PS: I hate using Photobucket, but can't seem to upload pictures directly from my computer. They only come up as attachments when I 'upload a file'.
Spraggle
10 subs??? Wow!
Will that not overwhelm the normal speakers, given that you're having close to twice the number of subs to normal speakers ? Also, if there's room for that many subs, isn't there room for 7.10.4?
I know so very little about setting up systems; the whys and wherefores - I'm only asking these questions to understand, not to be provocative! :)
KelvinS1965
No problem I expected I'd get asked at some point; it's about headroom and coverage to avoid nulls: I really like the performance of my little BK XLS200 in my second room system, so I'm trying to replicate that at higher listening levels in a much bigger room by using the same drivers/cabinet volume. I may as well reuse the existing 15" since they will help reinforce the very low end that the 10" drivers can't produce.
I started testing with REW room simulator*. Initially with 4 subs, 1 in each corner (as that's an oft recommended layout), but found having an extra pair high up at the back gave a more even response, especially from seat to seat, so this gave 6 subs. To balance the 4 at the back meant that I ended up with a pair of 'twin' (2 x 10) at the 3/4 height, 1/4 width points at the front, hence the 8 x 10". These drivers are £90 each, so it's not too expensive to double up at the front to keep the balance.
The 2 x 15" will work well below 45Hz in the front room corners and should give at least the same performance as my previous set up (they were in diagonally opposite corners). In testing, driven by the same iNuke 6000DSP they hit 113dB @10Hz at the MLP and could hit above reference (115dB) @ 20Hz. In the new set up they will have an iNuke each (with the other channel on each iNuke running 4 of the 10"). There may be some increase in this output as the 8 x 10" will add a small amount, though I will filter them in the interests of driver protection. Given I typically listen at -10 to -8dB below reference, then distortion should be very low as the drivers will have plenty in hand.
Although I'm going to be using a pair of BK IW300 below the window on the back wall, the other 10" subs will be in MDF boxes made by the same guy who made my 15" cabinets. The 6 DIY subs work out the same cost as buying 2 more IW300, but they won't be seen so I won't even need to paint them, just assemble them.
The cost of 2 x IW300, another iNuke 6000, 6 x 10" Peerless drivers and the MDF boxes is similar to building another pair of 15" subs, so I could have doubled my existing sub performance by just duplicating. However my feeling is that these smaller subs will be more discrete and give better coverage at the 50Hz and above frequencies that seem more difficult to deal with in my room as I'll be able to have them at different heights (it's hard to lift my 15" subs I can tell you!).
I'm not going 7.1.4 as IMHO there isn't enough distance behind the MLP for the surround backs and the window gets in the way as well. I'm already experienced in 7.1 in my old set up and that had 2.5 metres behind the MLP for the surround backs, but found once they get near to 1 metre behind there is little benefit to having them. Since I'd have to buy something equal to my S150T for tonal matching, it gets very expensive too. I may eventually upgrade the 4 Atmos speakers, but general opinion seems to be that it's much less critical to have them tonally matched, so my existing spare M&K K5s will do for now: In any case they won't be visible as I plan to cover the underside of the pelmet with off white speaker fabric (and surround the speakers with bass traps too).
Sorry I went on a bit there...hope the explanation makes sense. :)
* Real room measurements show that the sim is pretty accurate in my room as it's a standard shape.
big boss
I have Simple Control, but found myself using Harmony exclusively. Couldn't really get on well with it.
Spraggle
It's clear that you value your bass more than me! I would have been more than happy with the two 15"ers at the front! My set up is one 10" sealed MA Bronze Sub ;-)
I can see what you mean regarding distance - I tried out 7.1 just because I had two spare Wharfedale Diamond 6Rs - I was too close and the 4 'rear' speakers overwhelmed the front 3. If I had dipoles and could have mounted them on the wall, things might have been different...
All in all, looks amazing - can't wait to see if the 10 subs do the business!
KelvinS1965
I've been sorting through the Oak floor planks into piles of 'good', 'needs scratches sanding out' and 'just needs a light sand', so no real AV progress at the moment. I've had success getting some quite deep marks out then re-oiling the whole plank. I'll be able to put the worst planks below the sofa/rug so I can have the best ones visible. It's worth the effort as the cost of a new floor would be more than my additional subs (priorities and all that ;)).
I'm also waiting on getting a flush ceiling mount for my X500 so I can finalise the size of the pelmet as the projector will be concealed within. The new French doors are higher than the existing patio doors so I don't have unlimited depth for the pelmet.
I also dug out this REW measurement of my existing subs (configured front left/rear right run off a single iNuke 6000DSP), so it will be interesting to compare the response when they are both front corner loaded and powered off separate iNuke amplifiers. I may add a Buttkicker or two to the main sofa, so there should be plenty of tactile response between the 2 x 15" and the transducers. I expect the 8 x 10" will be rolled off below about 25Hz, but between them they may add a few dBs to this response: I'd like to be able to hit 115dB @ 20Hz at the MLP, so we'll see what figures I end up at the end of the project.
The Dreamer
Hi Kelvin,
Your idea for subs is similar to mine. I have a couple of 15" drivers to use up front, and have been pondering what I'd do for balancing subs; considering 10's or 12's to be hidden behind my false walls along the side of the room, and, as you say, they can be mounted at different levels to help with moving/cancelling nodes.
Which drivers are you looking at? I was heading down the 'cheap and cheerful' from the car audio suppliers, but wonder if there are better options. (I'm sure there are, but at what cost?)
As none of the drivers will be working particularly hard (having so many - though I was just thinking 2 or 4 balancing subs, not 8!), my thinking was that cheaper drivers could work just as well, considering we'd not be asking much of them.
What do you think?
edit: Just gone back through the thread and see you mention Peerless speakers - off to Google those now!
further edit: Crikey! Not looking at spending that much!:eek::laugh: I was thinking maybe £50 tops per driver!
KelvinS1965
The Peerless XLLS10 are £90 each, which I didn't think was too bad. I want to remain consistent across all the 10" subs as I'm buying in 2 x BK IW300 (since they will be slightly visible in the room and it's easier than DIYing something to fit in wall) which use the same driver. I've got a 8-9 year old XLS200 that I use in my conservatory, so I've been able to use it (driven via high level input) to do some initial testing.
Typically mixing different subs seems frowned upon, however I've seen plenty of users on AVS doing it and my testing so far seems to show it working out OK. Essentially my sub system will be the 8 x 10" drivers so the 2 x 15" are just for very low end re-enforcement. It just means I have an extra crossover to deal with (in practice just roll off the high end of the 15" and a very gentle low end roll off on the 10").
The Dreamer
Ah, OK. My initial search uncovered prices of around double that - from falcon acoustics; £90 would just about be do-able.
I'm not too bothered about mixing different driver sizes and/or brands (certainly not at the lower frequencies anyway) - I do believe it's difficult to integrate ported and sealed subs though, so I'll be keeping all of mine sealed. Still a fair way off needing to sort this though.
...and I may well see how well yours works before blatantly copying it! :D
big boss
Logitech Harmony Elite on Amazon Prime deal for £139.99. It's the best remote I've ever had. Be quick if interested!!
KelvinS1965
Thanks but I've got a Harmony Ultimate which works fine for what I need. Since Brexit has knocked the exchange rate, my AT screen is probably going to cost more, so I need to stick to the plan. :)
markymiles
Looking forward to seeing how all the light control measures work out. Will try something similar at some point, if I can get them out of sight when not in use. I guess that's the hard bit :smashin:
Shame you have to have the tripoles on show given how much effort has gone into making the rest hidden. There's no inwall solution for those possible? Is it just money or performance related keeping those?
KelvinS1965
Simply put; they perfectly match my LCR and tripoles work so well in that position I can't think what else would be worth spending my money on, plus they were £1,500 the pair and you know how little used AV gear sells for these days... Being white I don't think they will be too obtrusive though.
I'm having more problems trying to work out the construction of the front wall to allow space for the ceiling Devore panels: My latest idea is to have two very flat panels on drawer slides, that go back inside the pelmet/front wall (ie near to 1 metre depth). That would give me nearly 2 metres total out from the screen covering the ceiling, so I'll have a nice black Devore 'tunnel' surrounding the screen.
However, the projector screen case will be quite wide so will get in the way of these panels. I may mount the screen case in the pelmet rather than to the ceiling, so that would leave a gap above for the panels. Just trying to work out how to physically do this as I don't want to give up and just fix the screen to the ceiling which means I'll be left with a white ceiling during film watching.
Similar threads
Trending threads
Latest News
Samsung Onyx cinema LED screen opens in Australia
  • By Andy Bassett
  • Published
Disney CEO Bob Iger steps down
  • By Andy Bassett
  • Published
Quantum Dot development could mean cheaper displays
  • By Andy Bassett
  • Published
Netflix launches daily top ten rankings
  • By Andy Bassett
  • Published
OLED TV sales exceed one million in Q4 2019
  • By Andy Bassett
  • Published
