when will HDMI become standard on AV ampss ?
Discussion in 'AV Receivers & Amplifiers' started by ARoss, Aug 11, 2005.
  1. ARoss
    ARoss
    Jan 21, 2002
    38
    Glasgow
    (if at all)
    Just a tad frustrated at the moment as I have a new TV and the amazing cheap and thin HDMI cable as well.
    However, from what I have seen, HDMI switching without hiccups/up/down/scaling issues and hassle/cost is still to hit the high-end stratospheres never mind the devices for the masses.
    Does anyone have information or an opinion when the AV amps/receivers will start to offer great HDMI support ?
    ..... in the meantime I better run another 8 cables to cope with most eventualities :eek:
  2. Son of Shaft
    Son of Shaft
    Mar 11, 2005
    157
    Breda
    The Philips DFR9000 has HDMI switching. Only 2 inputs though. Dunno if it switches trouble free, the unit is pretty new so there is little experience with it.
    Yamaha 4600 also has HDMI switching (3 inputs), costs a little more though.
  3. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    Denon is releasing the '06 versions of their AVRs in the next couple of months - i believe at least a couple will feature digital video switching
  4. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    Both Pioneer AX4 and Denon 4306 will have not only HDMI switching (2 in 1 out) but also will provide Transcoding of all analog sources to HDMI so that you can have only one HDMI cable to your display.
  5. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,650
    38
    +13
    probably when hdtv's are standard :p
  6. ARoss
    ARoss
    Jan 21, 2002
    38
    Glasgow
    so we're probably looking at 2007 before low-end units get the treatment ?
    ie sub £400 AV amps/receivers
    or does anybody think there will be a rush equipment coming out next year.
  7. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    not for switching - for conversion then it may be alittle longer
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,731
    The Borders
    +3,079
    ARoss
    Part of the problem being the availibity of HDMI transmitters from the hardware vendors has been pretty limited and also there are a multitude of Transmitter options with DVI and HDMI making it tricky to actually 'standardise' this technology.
    See http://www.siliconimage.com/
    A lot of the hardware that's currently on the market with HDMI outputs and inputs are using less than full spec HDMI chips - often they only carry a video signal; no stereo or multi channel audio.
    You can also have problems with interfacing DVI and HDMI kit as different generations of HDMI hardware has different handshaking protocols and not everything works as expected - see the April 2005 edition of HiFi News where they are reviewing the Denon AVC-A1XV AV Amplifier and suffer from intermittent video signal drop out due to handshaking problems with the projector they are using.
    I guess until such times as everything is bullet proof the hardware manufacturers will be wary of HDMI and the complications it can introduce into a system.
    It may be more costly but for now external switchers and distribution amps are more flexible and more likely to achieve what you require.
    Best regards
    Joe
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    component switching isn't even standard for the masses yet!
  10. big_marcelo
    big_marcelo
    And many display panels (like the Fuji which I'm hoping to get soon) onl accepts 'standard' HD definitions on the HDMI input (like 720p, 1080i, etc...) ....
    So, if you have an external scaler you can't do 1x1 mapping via HDMI .... although Fujitsu is apparently looking into it to enable 1366x768 via HDMI ..... which would be 1x1.
    Until then...... I'll be using my DVI switch....
    Cheers,
    Marcelo
