When will HD5 accept AtracPlus 320?????
Discussion in 'Headphones, Earphones & Portable Music' started by Twan1, Aug 28, 2005.
  1. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    hiya all,
    today i updated my sonicstage 3.1 to the new 3.2 This was all done without any problems.
    I have just ripped a CD using the new sonicstage bit rate AtracPlus 320 but when i tru to transfer the files onto the actual HD5 it says it is not compatible and it has to be converted to 256 or lower!
    I have now updated to the lateest firware on the HD5 (1.2) but doiesnt seem to have been an upodate for this bitrate.
    Anyone have any info on this would be greatly appreciated!
  2. HD3
    HD3
    Might never support 320kbps. the hardware might not support it.
    Don't forgot Sonic Stage is designed for many other players than the HD5 which may support the higher bitrates.
  3. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    ooooh yeah didnt think of that!
    Im hoping it does tho as id use it for sure, saving in WMA just takes up too much space but 320 should be quite a bit better yet still smaller files!
