When was the arcam A85 Updated please
Discussion in 'AV Receivers & Amplifiers' started by Seany boy!!!, May 5, 2002.
Tags:
  1. Seany boy!!!
    Seany boy!!!
    I'm after one, but i want to make sure i buy the one with the new circuitry design. Or have i got it wrong?, and is the A85 in fact new to the range thus has the new circuitry. If it has been updated ,how can i spot the difference? cheers (sorry if that sounds a bit Irish... I am)
    Sean
  2. baileych
    baileych
    Dec 21, 2001
    171
    UK
    I think that there has only been one circuit design.
    You can check the software version by holding down the phono/aux, tuner and dvd buttons on the front simultaneously. I think that version 2.2 is the latest. I believe that version >= 2.0 gives you the option to configure the tape 1 loop as a fixed level input and previous versions don't.
    See http://www.avforums.com/forums/showthread.php?s=&threadid=33673 for a discussion of the bugs fixed between version 2.1 and 2.2.
    Charles.
  3. Seany boy!!!
    Seany boy!!!
    On it's site, it mentions the new circuitry design. So did it come togather with the amp at the same time?
    Cheers pal ;)
  4. baileych
    baileych
    Dec 21, 2001
    171
    UK
    I think that the site is just comparing the A85 to the old Alpha range which it supercedes.
    Perhaps Arcam can clarify?
    Charles.
  5. Seany boy!!!
    Seany boy!!!
    That will be it i bet . Maybe john (calling john Dawson) can help;)
    Thanks again mate:)
  6. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Yup, only one circuit design, which is different from any previous models made by Arcam (or anyone else for that matter).
    The comments on software are correct too. Older software can be factory upgraded if required.
    HTH,
    John Dawson (Arcam)
  7. Seany boy!!!
    Seany boy!!!
    Thanks John;)
  8. lmccauley
    lmccauley
    Oct 24, 2000
    3,560
    Newcastle
    +343
    John,
    Your mention of software upgrades has got me thinking (dangerous, I know) - were there ever upgrades for the Alpha 10 and/or DAVE?
    The reason I ask is that I have the digital out from my Sky+ box connected to the optical input on my DAVE and when I change channels I do not always get any sound. If I change mode (i.e. Digital Stereo to Digital Pro Logic or vice versa) then the sound always re-appears. Just wondered if you'd ever come across this and if it was possible to fix. It's not a big deal, it's just slightly irritating.
    Cheers,
    Liam
