When space is tight
pandora77
Can anyone recommend an av rec or amp with a max width of 270mm (height and depth not a problem)? Ideally 4 channel. Speakers not purchased yet but cables in situ. The main purpose is TV sounds.
dante01
Width isn't something that varies between AV receivers and all receivers conform with the width you'd commonly associated with hifi components. Width will always be in the region of 440mm and definitely nowhere near 270mm.
pandora77
What about the new Sonos Amp - width is 217mm. Think this might do it albeit pricey
dante01
Sonos are very limited in terms of surround sound. The Sonos would be okay, but only if its limited surround abilities satisfy your needs? Make sure you check its capabilities before commiting yourself.
Also note that you'd need to add Sonos wireless speakers if wanting to use the amp as part of a Sonos surround sound setup. The amp is only 2 channels and not a surround sound AV receiver.
D
Deleted member 24354
If it’s just for TV why not a soundbar?
pandora77
Have you seen the brand new amp - its 4 channel @ 125w. Think I may have to bite the bullet and spend the money.
Sloppy Bob
£600
4.1 as opposed to 5.1 so no centre channel for dialogue.
Limited format support, I can't find anything definitive on this (why isn't it on the Sonos site) but their other products manage DTS at best. No HD audio formats, no Atmos or DTS:X which other AVR's can do for nearly half the price.
I wouldn't spend that kind of money on that limited a system. You're looking @ £1100 minimum with no sub and the cheapest Sonos speakers.
D
The new amp is 2 channel, so you would, as @dante01 says, also need a wireless pair for surround or you will need 2 amps which would be £1200, for which you could buy a much much nicer AVR. I think that you need to accept that your space constraints are going to prove to be limiting or very expensive.
