When is HD ready really mean HD ready?
Discussion in 'General TV Discussions Forum' started by antfuller, Mar 18, 2006.
  1. antfuller
    antfuller
    i have an evesham 27" lcd ready(??) lcd tv, now, it only has a vga port on the side so in theory is it HD ready?? Have i been shafted??:mad:
  2. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    What model is it?
    If it is the V27DMCX-ZE3 then, yes it looks like you got shafted if you thought it was a "HD Ready" TV
    I notice that Evesham label it "HDTV Ready", a subtle but rather naughty difference.
    The HD Ready logo implies that the TV will have certain inputs that are compatible with HD devices.
    I am guessing, but don't know that this set might be able to accept a Component HD signal via its D-sub (vga) input. But I don't know. If it can, then it would be OK with a Sky HD box.
    If it can't then I would send it back if they implied it was "HD Ready", or even if you misunderstood it yourself because of their "HDTV Ready" branding.
  3. DynaMight
    DynaMight
    Jan 30, 2006
    157
    +4
  4. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    don't forget HDCP
  5. DynaMight
    DynaMight
    Jan 30, 2006
    157
    +4
    HDCP will be covered by HDMI/DVI wont it?
  6. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    Not exactly. You can have a DVI/HDMI without HDCP but the new HD format demands both the display and the source are both HDCP or you won't get an image.
  7. The_Censor
    The_Censor
    Nov 20, 2005
    280
    Belfast
    +8
    I know you can have DVI without HDCP - Not so sure about HDMI though.
  8. arfster
    arfster
    Jan 17, 2006
    1,459
    63
    +132
    "HD Ready" very specifically means 720p and hdmi/dvi. "HDTV ready" means nothing, and is just the advertiser trying to scam consumers.
