wonderloaf
Established Member
Hi all, just upgraded the memory in my PC and not getting the results I was expecting, hope someone can give me some insight into the problem..
I have an Hp xw6200 workstation running XP professional which up until about 30mins had 3Gb of PC2-3200 RAM fitted (2 x 1Gb, 2 x 512Mb). Going to My Computer/Properties showed 3Gb total as expected. I then removed the 2 x 512Mb and replaced with 2 x 1Gb and re-started. The boot up screen showed a new configuration of 4096Mb (4Gb) of RAM, but My Computer only shows 3.25Gb, so I ran SiSoft Sandra and that reports that I have 4 banks of 1Gb memory but the total is only 3.25Gb. I would like to add that all the RAM fitted is HP approved and although by different manufacturers is identical in specification.
The following is from SiSoft Sandra:
System Memory Controller
Error Correction Capability : m-bit ECC
Number of Memory Slots : 4
Maximum Installable Memory : 8GB
Bank 1 - DIMM1 : JEDEC ID:7F 7F 7F 7F 7F 51 00 00 72T128000HR5A 12520D05 DIMM Synchronous DDR2-SDRAM 1GB/72 @ 400Mt/s
Bank 2 - DIMM2 : Micron 18HTF12872Y-40EB3 BDD404D7 DIMM Synchronous DDR2-SDRAM 1GB/72 @ 400Mt/s
Bank 3 - DIMM3 : Hyundai Electronics HYMP512R72P4-E3 39320000 DIMM Synchronous DDR2-SDRAM 1GB/72 @ 400Mt/s
Bank 4 - DIMM4 : Hyundai Electronics HYMP512R72P4-E3 31320000 DIMM Synchronous DDR2-SDRAM 1GB/72 @ 400Mt/s
Looks to me as though their is 4Gb there, is this just a reporting error (hope so!)? Any coments on this very welcome!
